turning off s3 camera sound no silent mode or rooting needed (o^^)o
Unfortunately, it didn't work for me.
With a mark next to "Disable STREAM_SYSTEM_ENFORCED"
I get a message " Successfully set volume to 0."
With out it I get " Successfully set volume to max."
Either way the shutter still sounds and there are no new settings option to turn on or off the shutter sound.
I'm having the same issue as JammanX. Now I want Enforced Stream Silencer off my phone and it won't let me delete the program. Anyone know how I can delete it?
Welcome to the forums!
What error do you receive when you try to uninstall it?
You are attempting to uninstall it using the Application manager, right?
I just installed it, used it (it worked fine for me) and uninstalled it without any issues.
Edit: although I did have to reinstall it, uncheck the checkbox and then uninstall it again to bring the shutter sound back.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
jmyoung48
