Twitter notification sound?
I've just reported this issue to Twitter again via the about section within the Twitter application, I'd advise those experiencing this issue to do likewise if you haven't already.
THE FILE EXPLORER SOLUTION WORKS
I had this same issue on my Galaxy S7, and after reading this forum I went and downloaded ES File Explorer File Manager (although I'm sure any one would work), selected it as the default method when I tried to change my Twitter notification sound, selected the sound file I wanted, and then uninstalled the app.
Actually no it doesn't. Confirmed here and on multiple other forums. Twitter needs to fix this or there needs to be a reliable workaround.
I totally agree, they need to fix this sound ringtone issue, they had the chance to do so recently with recent update but failed miserably.
I fail to see how using es file explorer will help as when in twitter settings it doesn't bring up apps to use as I stated earlier.
Also if the solution only works with certain phones then it's not a solution at all.
Previously, clicking the ringtone setting brought up the default list of notification sounds. After downloading a file manager, clicking the ringtone setting gave me a pop-up to select my default media selection app (stock media player or the file manager). Choosing the file manager opened it, allowing me to go through my files to find the downloaded mp3.
Not prepared to download a file manager when Twitter should be fixing it.
Please know that I don't think it's right that we have to use this method, nor am I condoning Twitter's lack of a fix for this longstanding glitch. I simply was offering up my praise for a workaround that was successful for me and recommending it for y'all to use.
vean que el los foros de hack se habla de este tema por que es un error de las versiones ,para que se vallan a los foros de hack hay hay app para solucionar este problema de audio..
Have an S7. Can confirm, Twitter notification sound is reverting back to the default, every time.
I'm having flashbacks to when the keyboard would freeze within Twitter on the S4. (Took them a year to fix that,)
Another update from Twitter yesterday and still no fix for notification ringtone.
There's an alternate solution if you want silent notifications for tweets!
Go to Settings > Image and sound and disable "Sound effects". That's it, no more sounds when you receive tweets. Of course, if you don't want them to be silent, then you'll have to use ES File Explorer - or wait for Twitter to get its **** together.
There's been around 6 updates recently and not one has fixed the problem despite users informing them about it.
Got a S7 and nope not working for me either and I really want to change it back to what I had it as. Come on twitter.. i want my sounds back..
Yeah it's still not working and very frustrating. It took Facebook awhile to fix a similar issue for icon badges and their recent update seems to have fixed that particular problem as they weren't showing for a long time.
been having this issue for a long long time and finally looking it up, only to see that there is no fix yet.
this is happening on my samsung galaxy s4, note5, and nexus 6p.
looks like it's either an os or app issue, but i guess no one is gonna budge and fix...
I actually think it's outrageous with the number of updates there has been and not one of them has fixed this issue!
kctraci1
