Verizon Galaxy S3: 4.3 update questions and issues!
Re: Galaxy S3 4.3 update questions and issues!
I had the same issue with my Ford Fusion. I deleted the Sync connection on my S3 and deleted the phone from my car's system. I re-paired them and it works just fine.
They are under the lock screen settings menu. You can turn them on and off there.
Sent from my Samsung Galaxy S III using Android Central Forums
How? I want camera widget in lock screen. Lock screen>Lock screen widgets>Clock or personal message. The only options available after 4.3 update are clock or customized message. How do you add camera widget to lock screen? I have Verizon Wireless Samsung Galaxy S3 running Android 4.3
Well the lag is reduced now that I've done a factory reset. Still not great though. I remember it being much smoother when I first got the phone. I wonder if they design it into these updates so you're "forced" to get a new device.
Get into Developer Options and turn the animations off.
Settings
Developer Options - Turn it on.
Adjust animations
I am having the same problem as you I have Verizon. I have several apps I do not want to delete because I do not want to start over in my games. I am glad I am not the only one with this problem. Verizon needs to fix this. I was so much happier with 4.1.2. it is also annoying to have to swipe to unlock after to tap on a notification in order to view it. my battery sucks much more than it used to. it was already bad but now it is much worse.
What's up with the transparent icons after moving them to external sd card?
When you move an app to the SD card the icon does indeed turn transparent. But if you tap/hold/remove it from whatever page you're on then simply bring it back from your apps list it will go back to its original state.
Anyone know if its possible to change the lock screen wallpaper on an unrooted S3? I am on corp phone, so it's a password unlock for me, so no lock screen widgets, etc..
Since I downloaded the new software last week, I can no longer sync into the bluetooth in my vehicle. It used to be automatic as soon as I turned my vehicle on, but now I have to do it manually, and even then, it doesn't consistently work.
I tried re-syncing the phone onto the bluetooth to no avail. Any ideas ??
If its ford SYNC, Delete your old bluetooth devices, then resync brand new, the autodefault of what the vehicle is looking for has changed a bit, so I had to, it fixed it. Let me know if thats not it..
Im having wifi connectivity issues, it cycles three times... any thoughts on how to stop that, That is the ONLY issue i am having. its almost as if the radio on the wifi weakened after the update, which i know to be false....
Just because the Wi-Fi hardware didn't change doesn't mean that Wi-Fi behavior/functionality didn't change, possibly for the worse. They commonly update the radio files (aka Baseband in Settings -> About phone), so it's possible that they made a change that's having a negative impact on your reception or connectivity. The only way to compare would be to flash the radios from 4.1.2 while keeping everything else constant.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
Im not rooted.. So i cant flash them.. I guess i should.. Can you do that without rooting? I know on the fasci you had to..
I am having an issue with my phone rebooting everytime I try to access the clipboard. I tried the fix that Smeags offered, but it didn't work for me. My phone isn't rooted, nor do I want to root it. I rebooted my phone several times, & the test service app I force closed doesn't restart & isn't running. Anyone have any other ideas?
I am seeing the black webpages but I just tap the screen with my finger and they go away (on chrome). Have you tried just touching the screen and moving it up or down? It has worked every time for me.
I'm having this same issue and I'm seeing these black webpages a lot, way too much for my liking. I don't like any of the other browsers and I'd like to stick with Chrome, so does anyone know how to fix this issue?
Sorry, I forgot to include quotes. It does this on my chrome as well. However, if you just tap the screen on the part where it is black then it should reappear normal. It only does the black screen if you leave and come back. Have you tried just tapping the screen with your thumb or better yet moving it up or down like you were scrolling on the page?
I have a few issues but will keep it simple to start off. My first problem is that with the update some of the settings don?t seem to be calibrated. For example, my screen is really bright on the lowest setting ( all the way to the left). Turn it all the way up it is really really bright. To compare to music it is like the screen brightness went two octaves higher. The lowest setting is still very bright. During a phone call also on speaker I couldn?t turn the volume down all the way. The best I could compare it to is when someone that can't whispers tries to whisper and yet it is still loud. I wanted to turn it down to whisper and I couldn't. The lowest setting was still very high.
My second issue is the battery percentage is weird. It will charge and charge and charge and be at like 54%. Others have commented about it taking much longer to charge. Hours and hours. Then, all of a sudden I will look away and like 5 minutes later it says 100% charged. It is not possible to have charged that much that fast. The best I can compare it to is a faulty gas tank gauge. I really don't know how much gas I have. On a side note it drops really quickly from 100% to the 60% range almost within the span of 45 minutes or less then drops a little less quickly. I wonder if that is anyone else's issue. Again, this seems to go back to the calibration issue a little.
So after a lot grief, I just decided to do a factory reset. That cleared up the clipboard problem, but created a new one.
Now my webpage freezes. The page loads, but then nothing; I can't scroll or click on any links, then I get the dialog box that says my internet stopped working. I'm using the browser that came on the phone as I've always used it without issue before.
Any advice?
I'm also having problems with low audio on the S3 4.3 update. I have revision L710VPUCMK3. Is this the latest version?
Are there any possible fixes? I have all the volume settings set to maximum, but call volume is hardly audible.
Any advice?
Did you go to the application manager and clear cache and clear all data? Sometimes when mine messes up just once it continues until I do that. Not sure that is a fix or not but worth a shot. Let know if need instructions.
I'm not rooted.. So i can't flash them
You can flash just the radios using Odin. I'm sure you can find them on XDA - that's where I found them the last time I was fiddling around.
Of course, then you'll also have to find the 4.3 radios to get back to where you are.
RevRockinrick
