Verizon- pie update?
Ok so i was sucessful with side loading CSAA but when I try CSB3 install it still fails, my security patch still shows January. CSAA should bring me up to FEB. ? any suggestions tried numerous times with the install.
You need the file CSAA to CSB3 now
I havent had any more bluetooth devices remove themselves anymore but it's only been one day since csb3 was installed. if it happens again I'll factory reset to see.
I ended up doing the SD card. But now I'm starting to worry, afraid I won't get OTA updates. I just thought since it wasn't an official OTA update from Verizon I would be able to go back to Oreo by a hard reset.
Did you try the SD card or waiting on Verizon?
No worries
You on the last one CSB3?
Factory reset only restores the files on the current software you have .
Ok good!! Yes Verizon sucks!! I was trying my hardest to wait, but I gave in!
I dont blame you for giving in , we all did .
I'm surprised with them as big of a company they are they must of ran into some issues.
At least your on pie , hope your liking so far.
Ashtonnc
