Verizon- pie update?
can anybody help me downgrade from pie to Oreo using a Mac? I'm on Verizon
You can use the Verizon Upgrade assistant. There is a mac version that I have tested, and it works great. As noted by a previous user, this will pull whatever Verizon has as it's last update. This would be Oreo for the moment. Once Pie is released this would be the current version. It may pay to just wait, use the repair option will then bring you right to date with the version of pie released by Verizon.
Just came out to the forum after a few days. I see there is a update to Pie. When I go to the link, I don't see the current CSAA build number as the version to select as the current version.
Sorry if this was addressed already.
Its CSAA to CSB3 feburary security update
Save to Google drive then copy to sd card
You need the file CSAA to CSB3 now
Hey Mustang first off I want to thank you for responding. Tried again with the csaa download and the security date still shows January. This is the one I am side loading.
CSAA has a security date of January. You need CSB3 to get February
Ashtonnc
