When was the end of your billing cycle? Date? And are you on contract?
Off contract and end of billing cycle was 10/9
Yeah, it'll be on your next bill for the cycle ending November 9th. The notification I mean, not the charge.
I'm thinking of metropcs, but the rest thatvi know of are:straightTalk, cricket, virgin mobile, boostmobile
Currently they are a Tmobile mvno. Before they did have a cdma network but it has been sunset. They no longer operate any network, and strictly run off of tmobileMetroPCS isn't a MNVO from what I remembered as they did have a network. Looks like they use T-Mobile after the merger but before, they had their own CDMA network.
https://en.wikipedia.org/wiki/MetroPCS
Here is a list of MVNO's but not sure how up to date it is and if it's complete:
https://en.wikipedia.org/wiki/List_of_United_States_mobile_virtual_network_operators
It doesn't support att primary lte band 17. But it does support lte band 4, which is a secondary band for att.ATT is decent. I will have to look into Cricket. Wonder if I can take my vzw note 3 and still get gsm lte in Cricket?
so lte reception not as good? how about lte speed mbps?It doesn't support att primary lte band 17. But it does support lte band 4, which is a secondary band for att.
Sent from my Verizon Samsung Galaxy Note 5
Assuming that you are on band 4, then both phones would get the same speed. However, the Verizon Note 3 doesn't support bands 2,5,and 17 which the att version supports. So this means that you won't get att lte unless you are in an area where att has deployed band 4 lte. Which means that you might see lower speeds as att band 4 isn't deployed everywhere, and band 4 doesn't have as good penetration as band 17 (700MHz)so lte reception not as good? how about lte speed mbps?
Sent from my DROID RAZR HD using Tapatalk
The new plans are not priced for subsidized phones.
Logged into my Verizon and the message popped up
