What are your favorite cases for the Galaxy S6?
bogdaryl, what's the verdict after a couple days of use with the Lifeproof case?
I will be keeping it. I can deal with the minor issues in lieu of the protection it provides. I am pretty active, I'm outdoors a lot, and I work in law enforcement where I may get caught in the weather from time to time.
Cool, how did you crack your Zagg glass? Was the phone in the Defender when it happened?
Will you go back to the Defender after using the Lifeproof?
I was putting the phone into the Symmetry case and I guess I pushed to hard on the top left corner causing a hairline Crack in the glass. The crack was just across the corner though. I don't know if I'll change back to the defender or not. It's possible I suppose. I like not worrying about water intrusion. And the lifeproof is pretty well made this time.
Sounds like a tough choice.
I'm just going to have break down and order one. :-\
What are the minor issues you are experiencing ?
The only issue I've found is the bottom speaker has a slightly diminished volume, I'm not saying it can't be heard and I'm not saying you can't hear it at all I'm simply saying the volume isn't as loud as without the case on. The normal issue for me is standard for all of us that really prefer to protect our phones and that is the case does increase the size.
No I didn't replace the screen protector, I'm leaving it like it's supposed to be in the Lifeproof. I didn't purchase the warranty.
I don't advise anyone to buy or not to buy anything, I personally like the case and enjoy the protection it provides. I don't mind the above mentioned issues. I have seen what folks in these forums can be like if they get something that someone else sings praises of and it doesn't live up to their personal expectations.
^Are the grip parts on the Speck Grip the really soft rubber and not a hard TPU type? Is it really protective as claimed?
Thank you!
Grips are kind of soft., I really like this case, haven't dropped it yet, but pretty confident that it would work as it should. The fit is really tight, tough to remove. The grips help it from rotating in my front pocket, keeps it vertical
Galaxy S6 Clear Case Spigen Ultra Hybrid - it is excellent.
After always buying cheap ebay cases I decided to buy a decent case for my S6 and have not regretted it. Also brought their screen protectors and again have to say they have been great.
aravrajak
