s2kdriver80
- Mar 4, 2012
- 130
- 92
- 28
Thanks, will let you know!Hope the installation goes well!
You may want to rethink the screen protector. I tried two glass ones and gave up on both of them! First of all the ultrasonic FP sensor is NOT as quick-and-easy as an optical one such as you will find on most OnePlus phones. In fact, of all the under glass FP sensors I have ever used OnePlus makes the best IMO! Now the one on the S24U works just fine once you get your prints registered. But once you install a glass screen protector they all drop to a less than 30% accuracy...and I re-registered them AFTER the screen protector was installed. No sensitivity setting helped at all. YMMVI know this is like finding the Holy Grail for everyone but I'm getting a Ringke Onyx case for my S24u and I'm looking for complementing it with a glass screen protector that: 1) is edge-to-edge as nearly as possible, 2) covers the front camera (no notch), and 3) mostly preserves the fingerprint unlock function. Has anyone found a great protector for use with the Ringke Onyx?
I installed that, and my FPS went to crap for some reason.I went with White Stone EA glass it was 22.00 on Amazon worked great
It was like that for first few hours then ok but I did have touch sensitivity on during setup processI installed that, and my FPS went to crap for some reason.
Really wow! Cause I am afraid to take the phone out tonight without a screen protector. We are going to hear some live music and I want to take pictures and video. Husband said he wants a tempered glass one cause of the flat screen again but Best Buy doesn't have the zagg glass elite but the fusion one we have now with no fp issues. Now I am concerned which brands did you try?You may want to rethink the screen protector. I tried two glass ones and gave up on both of them! First of all the ultrasonic FP sensor is NOT as quick-and-easy as an optical one such as you will find on most OnePlus phones. In fact, of all the under glass FP sensors I have ever used OnePlus makes the best IMO! Now the one on the S24U works just fine once you get your prints registered. But once you install a glass screen protector they all drop to a less than 30% accuracy...and I re-registered them AFTER the screen protector was installed. No sensitivity setting helped at all. YMMV
How was that install? I watched the video and it looks pretty seamless.I went with White Stone EA glass it was 22.00 on Amazon worked great
Straight forwardHow was that install? I watched the video and it looks pretty seamless.
How do like WSKEN offering?these are the ones I tried:
I'm using ESR tempered glass, and the fingerprint sensor is fine other than needing to be pressed on a little harder.Also, there is a video showing sand, and gravel being tossed onto the screen and rubbed in to the glass by hand with no ill effects. So, apparently the geniuses at Gorilla Glass have finally come up with a screen that actually can withstand some fairly serious abuse. I think if I remember correctly that the scratch level went from a 7 (where they all scratched in the past) up to a level 8! So if you don't stand on it face down I think you'll be OK. I would certainly ask some more people what they're using and how well their FP sensors work after installation!
How is the fingerprint sensor sensitivity with the Spigen?I got the Spigen tempered glass protector for my S24 Ultra. Now that we have flat screens, these now longer need to be UV curing. The installation process was extremely simple and so far I'm quite happy with it.
The installation was different than anything I had done before, and it worked very well. I "can" recommend them, but then again I do not like having to push so hard to get my fingerprint to be recognized! I'm willing to bet that all of the glass screen protectors from the el-cheapos to the high dollar ones will all be the same in the end. So I guess it just matters what's important to you!How do like WSKEN offering?
I got these for my parents. Install was truly the easiest screen protector install of my life and flawlessly aligned.I had the amFilm tempered glass screen protectors on my Pixles and my previous Note's and was happy with them. I like the installer alignment tool, and they're inexpensive at $8.50.
I'm getting a S24U and a S24 Plus and already have two screen protectors sitting waiting.
This is the one that I have on the s24u and it works fine. No issues.Got my screen protectors today.
