Which is fastest/stable ginger-sense ROM?
Gee, I thought I was the only one who calls it dark and sinister. I guess you call that my Signature since all my ROM's have a similar look.
By the way, I posted version 2.2 today which includes my modified GS kernel with init.d processing working which increases RAM availability and speeds up the ROM.
Also, Tiny's kernel is working pretty good with my GB ROM's. I just don't include custom kernels in the ROM since they can cause problems and confusion.
Enjoy
Nils
Sweet! Fan-bloody-tastic to see you here on A/C Nils! I'm a big fan and proponent of your 3.0 ROM.
Had a quick thing though and would have posted it on XDA but my "one" post count won't let me post to the ROM's original thread.
I know you added the stocks app and widget back in the 2.1 version but I can't get either to work. I suppose I'm the only one who uses it as I read quite a few people who just delete it anyway. The app appears as though its there but when you put in a stock to track it just searches forever and never finds it...both on 3G and WIFI.
Other than that VERY minor thing I really dig your work!
I just got the community ROM up and running full speed...so far it's pretty slick but I think I prefer the themeing you've put into it. I'll definitely be firing up my Nand backup of 3.0 and updating as soon as I can get a chance.
Actually been a member here for a long time but never posted (too many good forums too little time HaHa). Just your basic lurker.
Yes, I did re-add the stock app in 2.1 by request but missed one important piece and it did not work right. Somewhere on XDA I posted the fix but it is also included in 2.2 that I posted today.
If you restore 2.1 you can just flash 2.2 over it without wiping.
Enjoy
Reactions: davidnc and Wanda
Enjoy
Thanks man, you rock. Restoring for a flash-over right now!
Oh and glad you got your recognition from XDA!
Getting an MD5 sum mismatch when I try to restore my v2.1 ...never gotten one before. Looks like it'll be a fresh install for v2.2 tonight.
@ Nils - Good to see you here! We're all big fans of your ROM's.
@ mistah_M - Flashing at work usually results in one sort of HR encounter or another! ;)
Enjoy
I was wondering why the stock app wasnt working correctly ,I had switched to another free stock app from the market since I assumed something was wrong ,sinced I did a full wipe before I updated to the 2.1.
Cool to know tho that I can just flash 2.2 over without a wipe needed, since I am still on 2.1.
I found a work around the stock "stock market app that didnt work.I didnt realize others had the same issue with the stock market app( or even used it haha) ,summertime(early fall) I am not on any forum(s) as much .
Thanks for your continued support/updates for this Great Rom
2.2 loaded and running. Slicker than snot! Stock app works though its still really slow to find the stock you're trying to load. Other than that its running 4.0.
Edit: stocks app working fine today...must have been just a fluke.
I'm fairly new to Rooting (tried 4 or 5 ROM's so far) and I've tried 2 of Nils Business Gingersense ROM's, 3.0 v1.6 being the last and love Sense 3.0 a lot, but cannot keep the ROM stable. I'd love to keep that one, but something doesn't mesh with my phone for some reason - Keep getting force closes and freeze ups.
I've also had similar issues with some other ROM's (Stock Gingerbread 2.3.4 being the exception as it seems to work the best) and wondering if it's an issue with how I"m restoring my apps.
I'm totally wiping the phone correctly - wipe cache 3x, wipe dalvik 3x, full wipe 3x, format boot, sys and data 3x, so that's not the issue. I'm using Titanium backup to restore and restoring manually one at a time (i did a batch restore one time and totally took up all my app space and restored stuff i didn't want, so I do it manually now). There's a handful of apps I restore the apk AND data as i have notes, settings, etc that would take too long to begin again from scratch. Could restoring the app data be corrupting the ROM's? I know restoring system data is a no-no, which i don't do (unless restoring music playlists is under that category).
Would love to go back to Nils Gingersense 3.0, but i need a stable ROM as this is my work phone. Any advice on why i'm having ROM issues would be appreciated...
Backed up CM7, full wipe/cache/dalvik FIVE times each, flashed 2.2, rebooted. Continuous force closes. Can't even navigate the home screen, one FC after another. I really don't want to move away from CM7, just wanted to try Nil's from reading all these posts.
I downloaded and flashed last night, clean install and besides the Market FCing on me in the very early stages of the setup, I've had no problems at all.
All I can think of is a bad download or a bad flash.
As far as wiping everything 3 times...to me it's overkill. It's not like the cleaning lady is going back over your kitchen floor and getting crumbs she may have missed...it's all one's and zero's. When you wipe it runs it's little program the same way each time, it either wipes it clean or it doesn't. I could be wrong after all I'm not a programer/hacker/really smart guy.
Not sure what you mean by formating the boot...thats a new one to me, never heard of doing that one. The only things that need to be wiped are "wipe data/factory reset"..."wipe cache partition"..."dalvik".
If it were me, I'd try a fresh download and a fresh flash. If you suspect its the download, you could try downloading it directly to your phone, just make sure you're on WIFI ;)
As I said above, the only FC's I've had so far are the Market but that was very early into me setting things back up. Maybe its your phone's way of saying it prefers to be unfettered by Sense in general:D
Actually Wanda, I think it was my sub-conscience asking me if I really, REALLY wanted to stop using CM7. :D
Wanda,
When you restore your apps after flashing, what do you do? Do you restore the apk and the app data?
Wanda,
Kinda depends...I keep my phone backed up with Google so after I log in the first time its starts to download the apps automatically...thats not always a good thing. It doesn't always download every app so I usually have to go into Titanium and restore some of my backups.
As far as apps and data...the only apps I ever restore with data are Cardstar (cause I'm too lazy to re-input all those stupid cards and I've lost most of them anyway), Colornote, and AngryBirds (standard version and Rio)...everything else is App only, never data, and restored through Titanium, and I do them one at a time. As you've found out, the batch restore isn't always a good idea.
I really hope it works out for you, it really is a kicking ROM I swear.
Ok, I guess the next time i have a lot of time available i'll try Nils Gingersense 3.0 v2.2 and just not restore data for my apps and see if it's more stable. Wish there was an easier way...
Thats what happend to me, so I guess I'm not the only one
Yeah, they won't let me tweak their server :D
baby boy
