Whitestone Dome for the Ultra has Blue Light Cut ?
Speaking of whitestone, anyone else ever have an issue getting one off? I had it on my S20 plus, it got a chip in it. When I wanted to replace it , it took me hours to get it off as it just kept breaking little piece off similar to a thin sheet of ice, what a nightmare.
It does crack since it's stuck on so well, but I notice that if you do it very slowly - and try to pry it from more than one spot, it will come off without cracking. Just have to do it real slowly and carefully.
I'm jumping in to this thread late but my Note 10+ came with a factory installed screen protector that I love.
It's served me well and I wouldn't go to the trouble of removing and placing another over the curved glass on this phone.
Does the Note 20 Ultra come with the factory installed screen protector or is the Gorilla Glass 7 (Victus) naked out of the box?
From all accounts we've seen with the unboxings and reviews on YouTube, it appears that it indeed will come with the factory installed protector.
Yeah I haven't had a good time getting them off. Idk if there is a special process but like you mine basically split into shards of glass
The way I do it is to pull with just enough pressure to let it pull away slowly by itself. If it starts to crack I move to a different spot
Next time try using a hair dryer at low heat setting to heat up the glue some. It will help in being able to pull the old protector off easier.
Its easy, i've removed all my WSD before turning in my old phone.
Simply lift one corner and gently lift slowly. It will come out. Don't rush it.
just got my WSD protectors. They came in the same bubble mailer that everyone else had. Luckily the glass came undamaged
Mine was just delivered also. I mistakenly clicked "shipping address same as billing" so I can't check for damage till I'm home. Hopefully mine traveled lightly like yours.
Just got my WSD delivered and they arrived alive, Thank God. Same cheap yellow bubble mailer as everyone else.
One thing I noticed is that the glass super THIN, I don't remember past dome glass being this thin?
On visual inspection without access to a caliper or anything, it doesn't look any more or less thick than the extra one I have for the s20+
The Dome arrived in one piece. But my goodness...all the crap packed in that box. Just when I figured I knew what I was doing, they sent me a 5k piece jigsaw puzzle. I couldn't even get it all back in the box. Lol
I'm telling you, ton of crap in that box.
I've never used the thick plexiglass piece with the target in the middle on past installs. :-\
Androidgenie
