Whitestone Dome Glass $32 (2 pack)
This will be my first time using WSD. They've had some positive reviews on this forum so I'm pretty sure I'll be good.
I've used them for 2 devices now. My phones take their fair share of drops, but always come out whole. The application is pretty straightforward. I watched a few videos and took the advice of my "forum family". No issues. I also ordered them for this phone.
I'm still afraid to try to apply these screen protectors, i think. :-/ Maybe this time with the S22Ultra....
I say don't bother. I never had one on my Note 9, and I hated the Whitestone on my N20 Ultra. Screen has held up fine, and I'll get the full trade in for it...
I hated the edges of the screen protector just a little smaller than the screen.
Sure, it has micro scratches, but I only see them when the screen is off.
And bonus - my FPS works flawlessly without the Whitestone!
Make sure to watch the YouTube installation videos for the Whitestone Dome protectors. It will help you a lot with the process.
Another positive :)Thank you!!!
Just a heads up, check to make sure your screens aren't damaged upon arrival. My box looked like it got smashed a little. Thankfully everything was intact.
Lol, same...Doorbell cam saw Fedex throw on porch. Box beat up but ok.
Just used the promo code to order a Whitestone Dome for my S22 Ultra. First time using Whitestone, though I have used Spigen's UV-applied glass in the past (surprisingly they didn't offer it for the S22 Ultra).
I like White Stone , been using them since Samsung s8 and on never had issues, got one for my s22Note Ultra over the weekend
Yep first thing I did when mine were delivered by Amazon UK.
Both screen protectors are fine :)
If this is your 1st time installing the WSD and you decide to go to YouTube to check a tutorial or two There is one you should avoid. The guy gets the job done but he seems to be in a rush, doesn't take certain precautions and following his process could lead you down a bad road. Looks like he's turned off the comments for the video so he must have received some pushback. The video TO AVOID is here
I have not had good luck with Whitestone Dome on my last two Galaxy phones but I am willing to try it one more time. But if the FPS has any issues again this time it is coming off, and hopefully not in tiny shards of glass like the others.
I cannot recommend the camera cover from Whitestone Dome though, if it covers the flash. I bought it for my Note 20 Ultra and it caused horrible image quality when using the flash. I replaced it with an ESR camera lens protector (which does not cover the flash) and no problem. Not sure if the lens protector for the S22 will be the same but if it covers the flash I would avoid.
Thanks for the info, I grabbed this one and I will return the one from Amazon to save an additional $10.
I'm thinking of getting one. How well does it work with the FPS?
I reregistered my fps after installing on my Note 10+. I had the phone for a few months prior to getting Whitestone Dome. This time around I have the screen protector and Otterbox case before the phone even gets here.
Well, the one disappointment of an otherwise awesome new phone experience is that I could not install my Whitestone Dome despite three meticulous attempts and prior experience installing UV cured screen protectors. I simply couldn't get the glue to spread across the entire screen. I gave up on this and will simply have an overpriced tempered glass protector installed by a professional at a cell phone store.
fabumix
