Why does my LG G3 keeps restarting unless plugged into a power outlet?
  • Start date Start date
Hi all,
Over the last three weeks my LG G3 has been restarting over and over again. At first it only occurred when using the phone for long periods of time. However it has now started to occur all the time.
If my phone is plugged into a power outlet it will not restart and it works as normal. Once unplugged it works for a period of time, however when I start using multiply apps it shuts down and restarts repeatedly until I either plug it into a power outlet or take my battery out. Taking the battery out stops the auto restart process however when I try to turn the phone back on, if it is not plugged into a power outlet the restart process starts again and continues.
I have tried factory resetting the phone but that didn't help the situation.
Any help or advice would be very much appreciated.
Cheers
Nathan
UPDATE NOV 2019
Just replace battery and solve this problem
Re: UPDATE NOV 25, 2017 : Why does my LG G3 keeps restarting unless plugged into a power outlet?
UPDATE NOV 25, 2017
This works 100%. Very easy, I promise.
Download The "WakeLock Powermanager" app
Then do this:
1. Open the app
2. Press on "Partial_Wake_Lock"
3. Now you shoud see "0 1 2 3 4" turn on at the top.
4. Goto Options
5. Check off "Autostart on Boot"
6. Unplug your phone
7. Voila, Enjoy!
Your welcome :-)
Paul
wow this wake lock app worked for my LG G5. ive bought 3 extra batteries and phone would go off randomly and wouldn't start if usb cable isnt plugged in. i was going to buy another new fresh battery but this really worked. i just restarted the my G5 two times without charger. wow. i can't believe it. i have 3 batteries which i can use now without fearing phone going off randomly. i also have lg g4 which had same problem but its battery was bulged due to overcharging but all LG phones have this battery problem. i had also tried reduing cpu clock by underclocking it with root and cpu app, but then camera and phone just lagged. can someone explain me how this wake partial lock works and why. thanks
Maxyguy666
