Why is my battery draining superfast?
A
AC Question
My android os is sucking up so much battery life. I have turned most of the services of and under night it sucks up around 50% even in battery saving mode :/ PS my phone sometimes skips a battery procent I'm on a Samsung galaxy s6 edge plus
LeoRex
Retired Moderator
Nov 21, 2012
6,223
Is your battery draining quickly? If not, I wouldn't concern yourself with the percentage. Keep in mind that SOMETHING has to use whatever power is getting consumed. Those core Android processes are just that, core processes. If your phone is sitting there idle for an extended amount of time, they should be at the top of the list because they should be the only ones that are consuming power.
Or... you have a grain silo. Your farmhand comes in and says "MICE ATE HALF THE GRAIN!!!" so you freak out and run out to the silo and look... and it's still full. Farmhand then says "Well, we only lost about a teaspoon worth of grain, but of that teaspoon that is missing, a mouse ate it."
TexasIndia
