WiFi blocking SMS/calls? help thanks!
bjbumgarner
3
Hey guys,
I am looking for some help here. I love the Droid X but whenever I connect to WiFi I lose signal strength so much that I don't miss calls and text messages. When I turn my WiFi and my phone reconnects to 3G I receive a flood of that were "blocked" by my WiFi connection.
Any ideas on the issue?
Thanks!
Just to cover the easy, are you close enough to the wi-fi location so that you maintain at least a couple of bars at all times?
I have the same problem...happened ever since I updated to gingerbread. I get a low cell signal and a lot of dropped calls when I'm connected to wifi. When I turn wifi off, my signal bounces right back up to 3-4 bars. Haven't found a fix for it yet.
FWIW, this does not happen here. At least, it doesn't effect my ability to make/receive calls or SMS. My cell signal bounces up and down so much regardless of WiFi being on or off I can't tell if there is any actual difference there.
I experience the same thing when using the leaks and I didn't wipe data, I usually hard reset to resolve but you can try wiping cache before going there.
Me too. When on wifi my mobile network state says disconnected; therefore, when on wifi I cannot receive calls. WTF?
Well it sucks that other people are having this same problem but I hope that means that it might lead to a solution... Anyone have any ideas or fixes?
Thanks!
Thanks!
Wildman did offer a solution to try.
jeromepare89
