word on the street is cold as ice will work on the Ov
yeah i fgured that out :P
i used ADB and pushed the apk to my phone and it startind FCing left and right put the old one back in all is well
Shameless Plug: If you want Apps2SD support (SD-EXT Partition support btw, not talking about Android's A2SD), There's a mounts2sd-based Mod here that should work on Quattrimus and any other rom here, I removed a couple incompatible binaries that the XDA version had in them for ARM7 devices (e2fsck kept getting overwritten with an ARM7 version causing boots to freeze. If your device is freezing after installing a A2SD mod, replace your ROM's e2fsck with your recovery's version using ADB in Recovery found in /sbin/.)
anyonw want me to change thid to make it more general? like V romss running on the S and vice versa?
dumpsterrentals75
