Wrong temperature in lock screen - S4 Lollypop
A
AC Question
After the Lollypop upgrade, the lock screen displays now the current temperature.
The default is F (Farenheit).
I changed it to C(Celsius).
It remained F, and now the temperature is plain wrong (183 F).
I cleared data and cache in the Weather application, but it didn't help.
I would like to see the right temperature in Celsius, or totally disable this information.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
It sounds like it is bugged. A factory reset may help but if you just want to get rid of it I would suggest turning off "Weather" under your lock screen options.
karim174
