[ROM][WIP][4.4.2] CyanogenMod 11 KitKat for Optimus S/V
skinbark
289
This is a basic CyanogenMod 11 rom for the Optimus S/V. It has NOT been tested extensively and I take NO responsibility for any bricked phones, data loss or damages that occur as a result of flashing any version of this rom. It requires ClockWorkMod 6.0.4.5 or later, or TWRP 2.6.3 or later, in order to flash.
What works:
  • Phone calling (ZVH and ZVJ radios require a patch)
  • SMS messaging
  • Wifi
  • Mobile data (thanks to thekraven)
  • USB tethering
  • Camera
  • USB mass storage, MTP
What's broken:
  • MMS messaging
  • Bluetooth
  • Wifi tethering
  • SELinux
  • You tell me
CWM 6.0.4.6 can be found in the rom directory. Flash Skinny_4.4_Gapps.zip after flashing the rom to get Play Store and Google Sync. Other Gapps will probably be too big to fit on /system.
https://www.mediafire.com/folder/nfgfef6qpril7/CM11
Contributors:
  • skinbark
  • bigsupersquid
  • thekraven
Special thanks to the CyanogenMod and androidarmv6 teams, also gu5t3r for GOptimize.
First! :-) really enjoying watching this progress once the major functions are fixed kit Kat should hold potential to be more responsive then jb on our aging hardware
I hope so, It's hard to say until all the pieces are in place and its loaded up with apps. I agree it should be at least as good as jb though.
Well I say should be better then jb because jb just flat out isn't supposed to work with phones that only have 512mb of ram and kit Kat is supposed to address that issue
Yeah it makes sense to focus on kitkat for this phone. 4.4 may be the end of the line for us though. We're already having to kind of jump through hoops as far as storage.
dmesg doesn't say anything when trying to turn on wifi, bluetooth, or airplane mode in settings.
kernel does talk about the camera hardware when it's in use though.
maybe android isn't talking to the radios yet correctly at all.
At the start of logcat on boot it says:
D/DHCP ( 102): failed to set ip addr for wlan0 to 0.0.0.0: No such device
Try this wifi fix in our init.qcom.rc
Gerrit Code Review
Whee!
Working wifi!
Code:
on property:init.svc.ril-daemon=running
    start get_macaddrs
#on property:gsm.version.baseband=V07u-000-000-MAR-23-2009
   start setapversion
this stuff, I disabled the GSM bit, and made it start the service regardless, but it didn't start the ril.
/system/bin/get_macaddrs isn't being built.
otherwise, the wifi fixes seem good. pinging Google.com in terminal works. haven't checked out the market yet.
Whee!
Working wifi!
Code:
    start get_macaddrs
   start setapversion
That's awesome squid! I resynced and I'm building now. It looks like they got the webview issues straightened out so Browser might be working. This is getting fun :)
It's getting interesting now for sure! Thank you guys for the work your putting into this. There's definitely people who said it wouldn't be possible
Skinbark, in the kitkat? Thread I asked thekraven if he would mind a link to his cwm 6.0.4.6 in the op here since currently it's the most functional recovery that can flash the cm11 zip. He said no problem, if you don't mind I think it'd make it easier for anyone just coming into this.
New build uploaded with working wifi(!). Browser works (needs to be installed). I took LatinIME.apk (AOSP keyboard) out of the rom to save space. Install it via sdcard and activate it in Settings > Language & input.
I have 6.0.4.5 uploaded in the same directory as the rom, I'll mention it in the OP for clarity. What's the link for 6.0.4.6?
Its in the same post a his 6.0.4.5 he updated it after I asked about sd-ext formating
;D
WiFi for me didn't work so whatevs. Kitkat is fun to mess with. Still haven't even thought about ART so...
#edit: is it normal for it to reboot when installing apps? :0
Sent from my HTC One SV using Tapatalk
I also got that when installing. Also locked up when rebooting normally a couple times.
Yeh locks up sometimes during boot and have to do a battery pull. I'll see what happens if I enable ART. (Probably nothing except crashes or stuff...) Seems pretty stable alpha 5. Good work guys! Running at 748/806MHz pretty smooth.
ART not included (currently won't build for armv6).
I expected that much...
Like I said, super stable guys! Loving the work being put into this device. My Motorola Triumph is kinda glitching on JB...
snacks1233
