Battery stats normal?
GS5TR
117
Is this a normal percentage of my battery status? Also my phone is getting a little bit warm just while doing nothing or in standby ( screen off ).. , next thing is that when I go to software update and it keeps loading and loading but doing nothing? Can someone help me please.. i need some amazing battery tips en tricks..
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,618
4,760
113
The high Mobile Standby percentage suggests poor cell signal--how is yours in general?
More battery stats would be helpful. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
If there is no way to show the Cell Signal Strength, then install GSam Battery Monitor.
Abdul Ali
