rhodest7
motofail works great I used it a couple weeks ago on 4.0.4
Sent from my GT-P3113 using Android Central Forums
I get this error when running petes program, another thing I noticed is the bionic is not listed as a compatible phone to be used by petes program
ERROR: adb could not be granted root access via local.prop method
Try again from the start, but if the problem continues, check your version
of Gingerbread -- hopefully you don't have a version where this exploit
was fixed.
PC OS info:
windows xp 2600.xpsp_sp3_gdr.120411-1615
Droid Bionic info:
system version 5.9.905.xt875.verizon.en.us
android version 2.3.4
basebande version cdma_n_04.07.02r ltedc_u_07.1f.00
kernel version 2.6.35.7-g4fc328e
build number 5.5.1_84_dbn-74
prl version 15142
any ideas??
This is what I used to root .246 (the ICS OTA). Worked perfectly:
How to Root ICS on Droid Bionic and Motorola Android! | Droid Bionic Root
Oh, and if your skeptical (you should be) I can vouch he's an XDA dev in good standing.
Will this procedure work with the new Bionic OTA Jelly Bean update?
I read you cannot Root Jelly Bean which sounded very strange to me.
No it won't. There is currently no known root exploit for jb. You have to root on ICS and protect root with voodoo in order to keep root thru the ota.
sent from my icy Bionic with a side of jellybeans
