Hydro kernel says don't use with cm7 so there's your problem
...I try to avoid messing with code I don't understand, I'm new at this. I'll look into this. Any idea where that code is?.....
I believe you are referring to the reboot menu at this point?
It's part of frameworks_base; best to overlay it like so.
Sorry if this isn't what you were looking for.
I put it there and it doesn't work
Sent from futuristic optimus s
Talking to buddlesplit
Before I put the time into it, would anyone want an updated version of this rom? I don't know if anyone actually uses it, so idk if its worth it.
If people want an update, is there anything you want fixed or added?
I just use your v build with edited build.prop and modded key files I'm good
Sent from my LG-LS670 using Tapatalk 2
Then here is another idea. Could you maintain a patch zip thing that will automatically do that and post it here along with my updates? (I'd do it, but I don't own an s so I can't test it at all, and I'm lazy.. )
Yes
Sent from my LS670 using Android Central Forums
