TWC42
Do you mean Samsung's "Simple Pay"?Not necessarily. If you use Quick Pay, you don't have to unlock your phone to access the cards. .
FWIW, I've given up on Samsung Pay and Android Pay. Mainly because there is too much variation in what the various terminals will accept.
It's easier just to whip out the cc and insert or slide it. They all work with the plastic.
Also, I had set up Samsung Pay, then set up Android Pay as the default. The first time I tried Android Pay, I could feel the phone vibrating as if it was using Samsung Pay (MST), and nothing worked.
As I mentioned previously, I like Walmart Pay, of course it only works at Walmart. I had read that it was very successful and installed at all Wallmarts, But the last two times I used it, it seemed that I was the cashier's first customer who tried it. One cashier had to call the manager to find out which key to press to finish the transaction, and another cashier kept insisting that I swipe my credit card even though I repeatedly told him that I was using Walmart Pay.
Too many inconsistencies to use the smartphone as a replacement for the credit card at this time. Have to carry the cc anyway, might as well use it as save some phone battery.
