Infinite Jest
I installed my second one today (the first had a good cut but I had transplanted it a few times). This second one doesn't have as good as a cut as the first and is bubbled up around all of the edges a good bit.
http://img.tapatalk.com/d/13/04/18/tytyjyny.jpg
http://img.tapatalk.com/d/13/04/18/y7eby9y5.jpg
As opposed to:
http://img.tapatalk.com/d/13/04/18/vepe6aru.jpg
So, I've been using this screen protector (Photodon clear for around 6 months and would like to give my opinion. Overall, I do not recommended this protector for the DNA, specifically for two reasons:
1. Plain and simple, the protector is too thick for the touchscreen to properly function. For the past half of a year I thought that the digitizer used in the DNA was a piece of crap as very often a light swipe or even steady scrolling would be registered as a tap or double tap. After finally pulling the protector off, I found out that this behavior was completely caused by the ~150um thick protector. I wound up taking a left over SGP ultra nano protector I had from when I owned a GSIII which is ~50um in thickness and cutting it down to roughly fit the screen area and sure enough, this thickness doesn't produce the touch issues.
2. After about a month of using the oleophobic protector, the surface became less than pleasant to use. If any amount of oils accumulated on the surface or my finger was at least a little moist, the finger glide on the screen felt uneven and with a lot of resistance. For reference, I've been using a cheap eBay protector on my iPad for around the same amount of time and the finger glide is much nicer.
