A
AC Question
how do i remove remote icon from top informtation panel
when i tap on that top notification panel I see blur tooth icon, battery, signal strength etc. AND there is the remote icon. When I pull down that screen the remote takes up a good part of the screen. I would like to remove it from that panel and open the remote on the rare ocassions I plan to use it.
