hi all ...
i am new with using android phones i have Samsung Galaxy Core GT-i8260 i think i made it root by using Framaroot app 1.6 (with Gandalf option) ... so i triad a lot of apps but it didn't work .. i always got this error :: " 'App2SD is not supported by your device. Because your device has a primary external storage which is emulated from the internal storage. You can link the app in order to move its files to your SD card "" i tried link2sd and app2sd and move 2 sd
thanks i think this thread is mention befor but i found no answer .. so i said lets refresh it ...
thanks
thanks
