polar135
I started having this issue, and i found that if i turn off my Bluetooth connection, my wifi automatically reconnects. I can than turn Bluetooth off and have no issues (didn't reset)
That does make sense with the problems I've encountered with both phones, since the FitBit uses Bluetooth (low power?) to communicate with the FitBit app on the phone. I didn't try turning off Bluetooth, though.I started having this issue, and i found that if i turn off my Bluetooth connection, my wifi automatically reconnects. I can than turn Bluetooth off and have no issues (didn't reset)
Is your Bluetooth on when your trying to connect?Just for a data point, I don't have Gas Buddy on my phone. My wifi issues are similar, but not exactly the same. My phone will only connect to some wifi's and the other it can see but won't connect too.
Acts exactly the same in safe mode as well.
I know it's a longshot, but I'm hoping Lollipop fixes it.
It's on, but not in use (The only thing it connects to is my car). I have tried turning it off and I still have the issue. Of course, all I did was turn it off and try to connect to the problem routers, I haven't turned it off and gone through every troubleshooting step (safe mode/wipe cache partition/uninstall possible problem apps/Airplane mode on and off/FDR etc, but I have tried all those). But just turning it off, it won't connect to the WAP (and right now it doesn't even see it) that's 2 feet from me.Is your Bluetooth on when your trying to connect?
Sent from my XT1080 using Tapatalk
Ok, well after doing a ton of research on this matter. Xfinity has been sending "WiFi hotspots" to everyone's router that is an Xfinity customer and that is causing connection problems. I was told by an Xfinity installer that Comcast is pushing this WiFi connection to our phones and it is something that will not be able to delete from the phone. But to get around this, I was told that when we can try and connect to Xfinity just forget the network and then I have absolutely no problems connecting to any router that is in range that I can connect to. Anyone wanting to try it and chime in and let me know what you find out. My apps have not been updated or even added since I discovered this issue. Good luck to all that try this, as it has worked for me flawlessly.
Since I've uninstalled GasBuddy I haven't had a single problem with my WiFi connection. I emailed the app developer a couple of days ago and haven't heard back.
