JJ Jones
What the heck...
I've disabled all bloatware, auto brightness, only sync Google services, etc. Do you turn mobile data off or something?
Very similar to me.
I also don't use a bunch of apps that will send me notifications. Only social media type app I use is instagram (I've heard Facebook app is murder on battery).
Mobile data is always on, WiFi is always on.
A little YouTube here and there, WWE app some, lots of chrome browser, Android Central app, Walmart app, play music, and Gmail.
Using Nova Launcher, not sure if it makes any difference.
I've disabled the Command Center widget as it is definitely a battery drain.
Since we seem to have similar setups, out of curiosity, what is the "assembled on" date of your phone? Mines 12/12. Based on my readings, I honestly believe there is a quality difference in some of the batches.
Sent from my Ballistic Turbo
