@Zackman, i noticed that the following isn't included in the update-script of the ROM, I'm not exactly sure if its needed or not, or what significance it serves, of if it's even needed at all.
Code:
assert(getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc" ||
getprop("ro.product.device") == "VM670" || getprop("ro.build.product") == "VM670" ||
getprop("ro.product.device") == "thunderc_VM670" || getprop("ro.build.product") == "thunderc_VM670");
EDIT:
Backing up my phone now, and going to try out the sd-ext scripts
EDIT:
Now testing if the sd-ext scripts worked, by installing as many random apps from the market as i possibly can
EDIT:
Well, I'd say after installing 153 random apps, it's safe to assume the scripts work xD
