chuckconnors
system apps cant and shouldnt be moved from internal, thats why the option is greyed out...
if you have an sd/ext then data/apps should all move automatically if using any flavor of quatt... its built in... thanks tdm!... (provided you have made one)... <--- this can be done from recovery... make sure you backup all your sdcard info to your pc before making an ext partition...
Thanks for replying. That's just it. I've got apps like Facebook that, by your description, are showing up as system apps (I can't move them to sd or phone). I do have the /sd-ext partition. I did restore my programs using Titanium backup and it seemed like it put a lot of them on internal memory and I had to move the ones I could using the 'move to sd' option. So I'm guessing all of these 'pseduo-system' apps like facebook are taking up space on internal? How do I fix this? Uninstall and reinstall from the market?
*EDIT* Here are some apps I found that I can't move: Google Voice, Listen, Espiere Launcher, Facebook (even after uninstalling and reinstalling from market), Maps, Mobile Surveillance, Overdrive Media Console, Radio Pup, SDMaid, Solitaire, Swype Beta, WeatherBug, Wifinder, Youtube, uTorrent Remote
I think some of these may need to be system apps, but surely not all of them, right?
