carloswii5
Tried the pre beta3 its awesome
Great work tdm good luck with the new kernel
Pre beta?
Sent from my MIUI (;
I'm still working through how to deal with languages between thunderc and sniper. The thunderc can really only accept English and Spanish or it grows too large. The current quattrimus code simply removed other language files. But the sniper folks have requested other languages, so I need to figure out how to make those coexist.
In the meantime, I've uploaded a CM9 test ROM to see how the multi-rom thing goes. It's built from a new tree on the server, but should be pretty much the same as the old tree (hopefully). This contains the multi-rom stuff, of course, and also the conditional code for the RIL that does baseband magic for thunderc and 3G magic for sniper.
You may notice that it's a bit larger than beta2. About half of the difference is due to the multi-rom files, and half due to the inclusion of FR, IT, and DE dictionaries in LatinIME (because I haven't sorted those out yet).
This is not well tested. Have a backup handy!
quattrimus-thunderc-cm9-beta3pre.zip
@tdm--- quick question... trying to view android_device_lge_VM670/ android_device_lge_thunderc-common on your git but nothing is there, just headers... have you moved the files since incorporating the multi rom installer?...
Lmfao sorry for this post but
Tdm is the calculator working because I'm helping my friend do her homework and I keep getting a decimal and I'm thinking uts e but knowing this is a work in progress I though I might ask
It works great, this is an arm cpu not a pentium.
Sorry tdm what was changed in pre beta 3?
Sent from my LG-LS670 using Tapatalk 2
What is the difference between cm9 and aosp?
Sent from my Kindle Fire using Android Central Forums
Getting nervous..... this is a great rom and there is barley any talk here anymore is this project still being work on?
TDM is still working on it, he's just on vacation still (I think). And the last post before yours was yesterday... Not that long ago!
