Battery life concern. Is this normal?
Lecrae116
771
I've had my sprint note 10+ for about 3 weeks now and this is my usage. 90% of the time other than spotify on the way to work my phone has been in my pocket constantly with little to no notifications.
msm0511
Trusted Member
Aug 23, 2014
4,619
9
38
Are you on LTE or wifi more? If you have poor LTE signal in your area with Sprint, which it looks like you may from your screenshot, that could be your issue.
msm0511
Trusted Member
Aug 23, 2014
4,619
9
38
Tower is down but does anything else look out of line?
One of the screenshots is too pixelated to see, but in the other one nothing seems too out of whack percentage wise. I do see that something is actively using your location. How often and how long does location active show in your status bar? Maybe Nexar or some other app is constantly uploading location to its servers in the background.
Lecrae116
771
Try these screenshots
Added 1 More Screenshot.
Last time I used my galaxy buds was during my l as+ Charge cycle.
msm0511
Trusted Member
Aug 23, 2014
4,619
9
38
Yeah, nothing looks too out of whack, so I'd definitely think it's related to weak signal more than anything. That's usually the cause when there isn't a rogue app going nuts.
Lecrae116
771
So your saying all my apps/services appear aren't going rogue including Google play services?
tekjunkie28
411
Idk, I don’t have a 10+ anymore and was thinking about getting one again but not after this. Bad signal and 7h 35mins on battery and it’s down to 38%???? Seriously? That’s pathetic. Question is do you have VoLTR on sprint? If not then it could be possible but that’s just crazy quick drop in battery. My note 8 does NOT do that.
msm0511
Trusted Member
Aug 23, 2014
4,619
9
38
Google Play Services is used by apps to activate your GPS. I'm not too familiar with Nexar, but according to the description in the Play Store is saves your route. If so, that may be why it's in an Active state longer.
Also I don't have Sprint so I can't search for it, but go into settings and search "diagnostics." If Sprint has a diagnostics tool, turn it off. It should be in the Mobile Networks section of settings.
Lecrae116
771
That is turned OFF already. I've got my phone to manually stay in medium power saver mode all day.
Lecrae116
771
Where do I go to see what's running in the background? Yes, I have VOLTE enabled.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,172
113
Don't judge off one person battery stat, as it will vary from person to person how they use the phone . If I see a pattern like 50 people on Note 10+ with battery drain then I'd be worried about getting that device. Something definitely going on with OP phone. So what I'm saying is don't be scared from one stat someone else has and make you rethink a device .
tress
