tekjunkie28
How do I get more stats without root?
You said you had a tower down. Was that fixed?
I've done that too.
Nexar. Its a dashcam app? Does it always sync or syncs only when you open the app? And how is your cellular data signal? Weak? Good?
Opps. I meant more stats within gsam app without rooting the phone.GSam battery in the Play Store.
The tower has yet to be fixed yet. Nexar only runs when I'm driving my car,syncs to the cloud then closes.I mentioned both Nexar, and weak signal earlier. Not sure that's the answer the OP wants.
You do need root it already provide enough without itHow do I get more stats without root?
I only use it to post certain pictures and then I disable it when finished. for reading, viewing, liking I use desktop for the ad blocking. can't take the onslaught of ridiculous ads.Instagram too
What info should I be looking for within gsam?You do need root it already provide enough without it
It will show your signal , on wifi or dataWhat info should I be looking for within gsam?
Phone radio - getting high , you use mobile data alot ? How's your cell phone reception?I know it hasn't been 24 hours but this is not good at all.
90% of the time during the dust me im not near wifi so Mobile data has to be used.Phone radio - getting high , you use mobile data alot ? How's your cell phone reception?
If you use data more then wifi especially 90 percent of the time then your battery I would say be like your stats.90% of the time during the dust me im not near wifi so Mobile data has to be used.
My phone doesn't want to deep sleep at all.If you use data more then wifi especially 90 percent of the time then your battery I would say be like your stats.
Probably notificationMy phone doesn't want to deep sleep at all.
Apps ? Facebook, Instagram, messages,etc.notification from What?
All those notifications are OFF except for text messages and calls.Apps ? Facebook, Instagram, messages,etc.
