trucksmoveamerica#AC
Trusted Member
Thank you. This should be stock. The only reason I kept AOD on all the time was for notifications. I listed the direct link below as aodnotify is not the exact title, shows as a different name. Works good so far, I'll give it my 24 hour test before buying it.Don't be afraid. Better yet, try aodNotify app. I love it. Turns AOD when you have notifications and back off when you dismiss them.
https://play.google.com/store/apps/details?id=com.jamworks.alwaysondisplay
