Why is my Note 4 overheating?
anon(5816156)
Active member
Dec 31, 2013
39
Re: note 4 overheating
Phone doesn't often overheat but when it does, the phone somehow became slower. Could be the cpu throttling.
It overheats easily when I used dark black cases. Use the counterfeit Verus case with card storage and it is easier to overheats indeed.
Lamoure
go to settings > battery and see what is using the majority of your battery power. A few days ago I had this problem where my phone was warm and the battery was draining like crazy. Turns out my phone was stuck on "indexing" and it went on and on for days. I did several trouble shooting techniques and eventually it stopped. Now everything is fine again.
What did u do to fix the "Indexing problem?"
syvohn nicholson
My phone is overheating bad and is overheating so much it burned my arm! This phone gets to hot and it is causing problems on the device! My clock does not even work!
Cavboygt
114
My note 4 overheat because of google apps that I don't use but installed by itself. I disabled most of them just leave google map and google chrome.
Note 4 strong Posted via the Android Central App
Andy847
813
6
My phone got EXTREMELY HOT when I downloaded the Lollipop Update. So hot that even in my Supcase heavy duty case, it was uncomfortable to hold in my hand. I checked online right away and people with the S5 having the problem were told to take out the battery, if you have an SD Card (Which I do), take that out for about 5 minutes and then pop both back in the phone. The Battery was Super Hot when I pulled it. After that, the phone was fine. It got hot one more time after that, but forgot why and I even talked to AT&T where they told me the super protective heavy duty cases sometimes trap the heat, so better with a thinner case. I tried that for awhile, but they were from my Verizon Note 4, so holes didn't all match. I ended up with an Incipio Casemate Case (Still had to go with a thicker case, phones too expensive not too in my Opinion) and my echo of my voice stopped once I got a correct AT&T case and I shut off the The HD Voice option in settings. Still get the echo occasionally, but usually when someone is speaking to me on speaker phone on their end. Changes with a regular call. I haven't really noticed the heat as much, but the phone can get hot if using a lot.
daviddsg
With wifi on, my note 4 gets very hot and action memo does not automatically load when I detach the S pen. With wifi off, the problems disappear completely. Is there a fix so that I can use wifi again?
plumcrazy
454
heavy user here, only time mine gets hot is when its in the car, in direct sun for a long time. its actually never OVERheated and shut down like my note 2 did a few times.
beh
1,378
16
What did you do to fix the "Indexing" problem?
I had the same issue with an old microSD card switched from a previous phone. My solution was to replace the card with a new one. Problem solved. At the cost of microSD cards from major vendors being so low, especially on Amazon, there is no reason to use old cards.
Tsepz_GP
1,385
Hi.
I have searched the forum for'overheat' and 'overheating'phares and couldn't find the solution.I got galaxy note 4 well today's afternoon just in one hour my phone got quite hot,by just keeping it in the pocket.
my battery level dropped from 90 % to 36% the screen wasn't turned on in my pocket.
Without using it I was checking it frequently for temperature,it's been hot for the next hour and completely drained out then.
After plugin in and start to charge I turned it on and it became hot again,unlikely the previous times I was charging,now that I finished charging after couple of hours everything is fine,no overheat or sudden batter drain.
are there any information regarding similar issues does anyone know what may cause it?
mobile data was on,phone was running like usual without any additional tasks.
I checked the battery drain indicator at 36% it was screen and android system on the first two places-but this is almost like always.
Before I return the phone I greatly appreciate for any help.
Brand new phones do that. The phone was syncing all your data, and once it was done it stopped heating up. Every phone does that at initial setup.
I wish people would stop freaking out so quickly over this 'overheat' saga.
haggistheoriginal
Hi there, Just thought i would share my experience. My Note 4 was experiencing the same high drain and heat issues from the beginning. It turned out to be a problem with the SD card (or at least a problem between them!) When I took the SD card out of the phone it acted like a brand new phone, high battery life and long lasting. There is a scorch mark on the outside of the case where the SD card was heating up!
BrittBeotch
Sad thing about this is, I have had three or four devices..... All of which do the same thing, overheat after having it two or three weeks. Terrible. Goodbye Samsung technology.
Umar Hafeez
13
Is it normal ??? My note 4 darins 1% in 5 mins . My all bloatware apps are disabled and phone is on power saving mode . I bought this phone on 28 june .
Yestarday i was charging note 4 . I touch the phone its like burining hot i take off the battery and cool down . Now again i charged and not happen again overheating .
Sorry for my bad english .
Umar Hafeez
13
Dpham00 , on 3:45 pm the battery was 87% after 2 hours of web browsing ,fb ,an 20 mins of playing furit ninja and rival the battery level was 62% on 5:45 pm . Is it ok ???
Umar Hafeez
13
Here is some screenshots .
