Setting aside the Note 4 utility discussion of this for a moment, do you need a flashlight on that entire time?
Many, many companies make really inexpensive motion sensor lights that come on when they detect movement, and they are plenty bright to find your keys and such. Most take standard AAA or AA batteries and you can use rechargeables. I use them all through my house and on my front porch so I don't need to leave lights on and the batteries last for months before needing to be recharged.
I have 6 units of an older (rectangular) version of these:
https://smile.amazon.com/gp/product/B00EIIDA1Q/ - the light comes on when it detects movement and stays on until 20 seconds after it stops detecting movement. They all work great. We love them.
If you need light out there all night, the newer model of what I have has "OFF/ON/AUTO" modes, so you can just turn it ON. I don't know how long a set of batteries would last but for $15 for 3 you could set one up in the ON position and one in motion sensor, and even after the one that is ON goes through its batteries for the night (or if you forget to recharge them one day) you at least have a motion-sensor-based backup that should operate for many months.
Alternatively you could set all three up in motion sensor but in different spots so if there is motion anywhere on the porch that section of porch will be lit up as needed. Unless you really need light out there the whole time, that should serve you very well and provide plenty of light where and when you need it, and you won't have to do daily recharges of it. Plus if it gets stolen you are out $5 per light plus whatever the 3 AAA rechargeable batteries cost.
