I thought your phone showed 1900mA. What was it plugged into then? And how much are you getting in your car?
Sent from my AT&T Samsung Galaxy S4 using Tapatalk II
Charger on, charger off. App doesn't work on my Verizon Galaxy S4...
What app is that? Is that showing the AMOUNT of mA it's charging at??? while plugged in?
I just plug in to the car usb port see attachment
Sent from my Galaxy S4 White - using Tapatalk
Strange that CurrentWidget works on some people's S4s but not others.
I emailed the developer and told him my issues. After some information exchange, he sent a new apk for me to try. It worked! PM me your email address if you need it now or wait for a Google play update coming soon.
Why does the current widget show the 460mA when it's not charging? Is that whats the battery is pulling from the battery or something?
I may be wrong but I believe it is supposed to read - 460. That is more accurate with the screen on and the phone off change.
Battery monitor widget gives a fairly accurate real time mA estimate
