Originally Posted by
Rukbat It depends on the connector it uses (I don't have one, so I don't know), but if it uses a microUSB connector, and your phone does too, use the phone's charger. If not, you'll have to buy a charger that will fit. (Don't worry if the charger is capable of more current than the original, only if it's only capable of less. The S3 won't draw more than it's designed to.)
You can easily find a OnePlus brand Warp charge brick and the red cable for less than 15 dollars. I will admit I have purchased 2 warp AC wall Chargers and both have completely died and will no longer charge anything. With so many phones now that feature a 30+ watt charging speed. So you definitely do not have to buy only OnePlus branded accessories. I have an off brand 30 watt Car charger that has really worked perfectly. I get the max voltage and milliamps hours every time. Once you get used to the warp speed charging speed compared to the standard. 18W or less. It's hard not to keep at least one good warp charger somewhere at all times.
Amazon and eBay have a good quality and cheap chargers that are Warp compatible.
