Fully stable working port of IcedCoryStreater
aka ICS
You must read this whole first post.
aka ICS
[WARN]
FAQ:
Q: Should the menu button work while on the home screen?
A: No. It doesn’t work at this time. It should still work within apps.
Q: Can I change themes? Kernels? I need Voodoo! BLN! CANDY!!
A: Chill. This is an SDK port that is in the early stages of development – it’s not even really supposed to work. Feel free to play with flashing these things, but nobody has had success with it yet, and don’t report any issues.
Q: Continuous sync symbol?
A: It’s an issue with one of your google apps. Make sure none are trying to update. Make sure you don’t have any incompatible apps installed.
Q: NFC?
A: No. An emulator doesn’t have NFC, neither does this rom, for now.
[/WARN]
Stop by and say thanks to turbofan for the F.A.Q.
All NON Sprint Nexus S 4G users Please make it clear when posting which version of the nexus you have.If you flash to a non 4G,I know about your issues please wait to post the problems.
This is going to be a work in progress.
Please don't copy&paste this thread elsewhere,just link to this thread.
Not everything will work from the get go on.
Im going to work on this a lot more for the rest of the day and should have a link up here later tonight.
Im still going to say it's a dirty post as things need a lot of cleaning up,but I know everyone is ready for a update.
[WARN]MAKE A NADROID BACKUP
Not my fault if you break your phone this has only been tested on NS4G from sprint.[/WARN]
If you want to help out please download and post anything you can to help or pm me and ill add it to the rom.
Small list of issues that im working on
-wifi <-- works almost all the time small issues.
-BT <--I haven't checked it out
Working
-3G audio doesn't work
-camera <-you'll get FC's sum times
-take it for a run and find out the rest for yourself.
-SU is now added.
Don't be shocked if it doesn't look or have everything that a official rom would have this is thrown together with what would make it work. If you want to change the look go for it.
Huge thanks/Credits to
warttack
for all his help.
Thanks to
- Cory Streater
- Charles Dolly for the help making it "Butterfly Smooth"
- Drew Walton for his server
- Paul O'Brien MoDaCo
-D2dyno <--Thanks.
-batting1000 <--for getting the icon and other things looking/working better!
-the few others i forgot ill add you once i get your name again
- Any and all that have helped gave ideas,tips anything
If i forgot you send me a pm and ill gladly add you.
[NOTE]
How to flash ROM
-Download ROM
-Place root of SDcard
-Boot into recovery
-Make Nadroid backup
-Full wipe data,cache,dalvik
-Should only need to cache if coming from 3.2
-Flash name of .zip
-Reboot
[/NOTE]
[INFO]TO Download the ROM you need to understand the following.
This is all done in fun, if you don't like it you are not forced to use it or even flash it. If you understand that this is all in fun and enjoyment then download and give it a run.
Agree
Yes No
ICS-dirty-alpha-3.6-current
ICS-dirty-alpha-3.5-old
ICS-dirty-alpha-3.2-old
[/INFO]
If you don't have a NS4G very good idea not to flash.
Once i get the edits made for other nexus version ill post them.
[YT]http://www.youtube.com/watch?v=Z2uW7txxVjM[/YT]
