quincyb2
Active member
Looks Great. If your still having problems with 3g quincyb2
was able to get 3g to work on his,
"oh i flashed the KF1 Radio and now 3G is working i9023"
3G is even faster than on Gingerbread
Yeah thats what Beezy has been saying for the 4g3G is even faster than on Gingerbread
I am in class, and all of you posting like wildfire are distracting me.
Alright, so if you are talking about the Live wallpapers, they are not in the SDK so no one has access to them yet. Your probably going to need to wait until we need a full system dump from a Galaxy Nexus or until we see the the source code released. If your talking about the regular image wallpaper then here is a link.How can i get the ICS wallpapers? Can APKs be installed?
This might've been asked b4, but coming from beta 2, should I wipe data? Or cache+dalvik is enough?
That's what he has been doing so far.is he posting updates right on the OP?
Should only need to wipe cache/dalvik. If you run into issues then wiping data will be the way to go. I always start clean as to avoid issues.
Thanks!
On another topic, please put ads somewhere or something (edit: your website...)!
I wanna donate (and I shouldn't be alone) but I need my scarce student money!
I received a pm back from beezy. here is my response. let me know what you guys would think if i was able to whip this up over the course of a couple days (i work full time so its hard to find time)
"thank you very much for the reply. i completely understand how famous you are to us nexus'ers and that your time is spent a lot on this thread and marching towards a complete release. I will also do what i can in efforts to backport the wifi drivers using logcatting and possible upcoming galaxy nexus sources. bln should be a somewhat easy task and i should be able to pull the config from a stock rooted rom. OC will definitely be included as well as some major governor adjustments to save some battery and improve ramping up/down time. also if you would implement it i would also plan on a slight RAM and display undervolt to ensure the extra processes created by errors in the rom are matched with battery saving techniques iva acquired over the last few years with android development. and if you dont mind would it be ok to fix up a lot of the pngs and also make some boot img adjustments towards healthy ram usage and proper ext usage with init.d scripts to promote zipalign and possibly compcache support. voodoo tends to be a lot of work typically so i dont beleive that will be there on first release :\"
beezy is the !
Must be the same one link then huh? I didn't see anything noted about "Alpha 1 dl" or Alpha 2 dl".
Have you downloaded and ran the rom,gave feed back,and helped people around the forum?!? Then guess what you are donating. I don't expect money for doing any of this its nice but not expected at all. As long as you do your part and help out the community by answering questions and help trouble shoot find bugs then I'm happy and grateful.
There is no update yet, but if you wan to manually do it here is a link to all of the icons.is there a ics icon pack update yet? ie phone and contacts?
