keebler021
Active member
Noticed that, but all the themes are ugly except the ICS one.
Oh definitely agreed, but it's still cool that they even threw in the option
Sent on Ice Cream Sandwich from the future of Android
Update.zip has nothing to do with ROMs as far as I know. It actually has to do with updating your phone to the latest version of software that it came with. You will have to use the Install from zip option to download a new version of a ROM and then choose the new version from your USB storage/SD card. Its always recommended to wipe when flashing a new ROM or an updated version of one.
Sent from my Nexus S 4G using Tapatalk
Bug: Whenever I'm browsing the web, I tend to get a lot of errors saying I have no network connection, but when I click OK, the page still ends up loading fine. My network connection is normal and this happens on wifi too.
Ok, can you backup your apps/settings and restore without a backup program such Titanium? Please bear with me, I'm a noob at this. First time ever flashing a ROM.
You can, but I don't know that I would recommend it with this ROM, as some have been saying that Titanium Backup doesn't play nice with ICS (someone please correct me if this isn't right). What you might want to do is wait until major updates to the ROM before flashing an update. Personally, as a flashaholic, I've just become accustomed to wiping everything ;-)
I noticed that the menu button works just fine on the home screen with adw ex.
I have a couple of announcements to make:
1) I am totally freaking jealous that you guys get to run this on your phones and I can't.
2) I'm not sure what the full change log is, but I know an update is in the works.
complete opposite here, battery life isnt great at all,
phone gets really warm too.
but i still dont wanna run anything else lol
it is what it is
OK i just updated to alpha 3.2-2 what's the changes if I may ask?
I was having horrible battery issues also. Enough so that I was switching back to cm7 while I was at work and back to ics at home. Then I did a fresh install from scratch and remembered to disable the Google restore and now my battery is as good as cm7 w/matr1x. With 2 1/2 hours of screen on time and 7 hours while I slept........
Long days and pleasant nights............
My phone was right out of the box when I flashes this rom. I'm getting awful battery life, and when I open a task killer and look at my available ram it says its only got 20% available with no other apps open. What gives? Is that normal?
How do you stop Google restore?
Thanks again,
Peter
