Batting1000
Need a dev first to make sure this is OK. Then I'll let everyone know, depending on if it's OK or not.
Got ahold of beezy. Will let everyone know.
I present to you...Beezy's most recent ROM update with the latest launcher in it, straight from the ICS app dump!!!!! Has the latest app drawer animations, launcher animations (page overscroll on the latest pages of the launcher), working menu button, and slightly changed notification tray!!! In addition, you'll get the little tutorial when first loading the homescreen like on the virtual sdk device!!
There is one bug which i'm sure will be fixed soon or not, but the google search widget at the top is very slightly cut off.
Here's the link. Either flash over the current rom or wipe then install.
http://dl.dropbox.com/u/15668564/ICS-dirty-alpha-3.5.zip
Enjoy!
Enjoy!
Enjoy!
App drawer is totally AWESOME! Loving the menu button functionality! Will the app folders stick now? Thanks a million!!!
Not sure about the app folders, haven't tried that. Try and let me know!
The only problem i noticed was the black screen, also on the home page, it no longer changes orientation. is that because it's the official dump?
