.35 Gingerbread/ICS Kernal
Well, I might look into it. But More importantly, I really wanna get us all ics! So I will start looking into some kernel stuff first, maybe get some help from xda guys. But I will try!
Sent from my LG-P500 using Tapatalk 2
And also, I may need some easy help, is anyone could figure out what drivers we need in the kernel for ice, that would be a HUGE help. Thanks!
i tried the Gummy Rom with my Thrive and had the keyboard problem too. Everything else worked. Had the same problem with the ICS based MIUI rom except I couldnt get wifi to work with MIUI one.
Everyone, i have successfully compiled the stock kernel from source with a couple changes but i still don't know how to integrate overclocking or specific kernel enhancements such as ones from cyanogen/other p500 kernels. I am in contact with a Respected DEV from XDA who is going to look into it for us.
Reactions: LifesGoodPhoenix
Thanks, but it seems a good friend, arjen, will be making us a Gingerbread specific kernel and an ics specific kernel! Give him many thanks!
@Oathkeeper & bluntman,
If this kernel works out for you guys, thats great! You guys deserve it after waiting so long.
BTW, your more than welcome to pass the word if the developer working on this kernel is one that follows GPL rules, etc. he is welcome to come here to AC and post & share it for all :)
Best of luck guys!
Hey, can you type out step by step how you compiled the kernel? I'm clueless lol.
Hey sorry i was out, here are the links i initially used to get everything up and running. Mind you, this is only for the stock kernel (i was trying to just modify it to add overclocking and different io schedulers, the latter of which i was able to do) You will need fedora 16 and all other things needed are explained in the videos as well as a blog post to tell you which commands need to be made)
Tutorial: Android Kernel Configure, Compile & Install (Part 1) - YouTube
Tutorial: Android Kernel Configure, Compile & Install (Part 2) - YouTube
OhHeyItsLou Tutorials: OhHeyItsLou Custom Android Kernel Guide
Good luck! If you have any questions feel free to ask. Also the CROSS_COMPILE command is wrong in the blogpost it needs to be :
(export CROSS_COMPILE=/home/{your username}/ndk/toolchains/arm-linux-androideabi-4.4.3/prebuilt/linux-x86/bin/arm-linux-androideabi-)
Also just substitute file and folder names. When you get to the make menuconfig is the cool part where you can actually configure every aspect of the kernel. I just can't figure out how to add overclocking and kernel patches, but i'm still researching!
Reactions: Oathkeeper1212
you just said it... "almost" (8... haha, just joking, you are right sorry, but my guess is that the kernel is being developed with gingerbread source of lg phoenix, so maybe it doesn't support obb of lg thrive or something like that, like raeneyes kernel that its buggy in data o:
OK so I'm starting the compiling process now. Will post updates if I get it compiled correctly
tuovst
