[6.25.11][ROM] BAMF Sense 3.0 GB RC3
Ok so now I've got the radio up and my 3g and LTE are back. Now all I need are my contacts and the back up assist zip won't show in the app drawer even though I installed thru rom manager.
wish i could help i backed my contacts up on my SD card to play it safe before i flashed this, and was a simple import to get them back
So I am running 2.06 remix currently.... Is 3.0 worth the change over? Any real issues?
well my battery did much better today, it's not quite as good as it was on stock, i left work at 45% today it averaged at 55% beforehand and i used it less than normal so wiping battery stats and draining it completely after def did help now on to figuring out what to tweak to get it to where it was before at the least i was thinking i'd get better battery getting off stock but maybe sense 3.0 eats a bit more (maybe i'll go back to the lean kernal), i def don't wanna go back to stock now though lol
is anyone else having there apps that are installed to SD constantly losing there icon in place of that generic android logo and completely losing them from being a lockscreen shortcut?
I did everything as stated. now i have no wireless or data. just wifi how do i fix this. im lost Thanks
Hey guys. I'd love this ROM on my phone that keeps rebooting every day. If anyone on here can help me through rooting my phone, s-off, putting the new MR2 radio on and adding the Bamf 3.0 rom that would be helpful.
I just did it. first time on thunderblot. Went pretty smoothly, minus the fact that i didnt know I had to flash a radio rom and didnt have any voice or data till someone helped me.
I used the ADB method. Very simple. The only help I can really give you cause Im not that knowledgeable in this yet is to download all of the files first have them ready to go. Be patient and follow the directions as stated, dont try to rush it.
directions for rooting...
http://forum.androidcentral.com/thu...ocedure-how-root-thunderbolt-adb-windows.html
this is where i learned how to flash the radio file
http://forum.androidcentral.com/thu...7-guide-upgrade-gb-sense-rom-radio-froyo.html
Also does anyone know how to get the weather lock screen to display the correct temp?
Do you have Weather sync on in Settings > Accounts & sync?
Yea I have the app sync on. Its displaying what I would believe is celcius instead of fer. How do I change. Drooped the app into click drag edit and also removed from home screen to try again no luck.
I fixed it... Thanks everyone. Put it on the home screens then open the app and change in the apps menu / settings.
I have problems sometimes picking up the current location for the weather app. Works fine when I switch to wifi. A very minor gripe for a great ROM.
One problem that has come up is, my phone turns itself off, but WILL NOT turn back on. I have to take out the battery to reset. Happens once or twice a day. Also my proximity sensor doesn't work... Any suggestions???
Did you wipe when installing? If not, do so.
Also, crank up your minimum speed to the next slot up, and see if it helps with the wake issues.
cecilyharper
