[7.14.11][ROM] Das BAMF Sense 3.0 RC4.9
I was using DB RC4.9 until yesterday and my GPS was working fine. What radio are you using? It may be a matter of reflashing the radio, or wiping and reflashing the ROM.
I tried switching radios still didn't work. I had the original mr2 then i switched to the new official mr2 and still didn't solve the issue. I even ref lashed RC4.9...So I don't get it. I really love this rom and don't wanna revert to an old rom but I use my gps a lot.
I dunno whats going on but i installed this rom and cannot get it to run correctly. i installed the mr2 and 2.5 radios to it also. As soon as everything loads up the phone just locks up completely. So i have to battery pull to restart. I just ran the cm7 rom and it installed clean and ran good but i like the looks and layout of the 3.0 rom. Can someone shine some light on this!!
I also have wiped and reflashed 3 times with the same result
Did you check the MD5 checksum on your ROM download? Could be a corrupted file.
Sent from my ThunderBolt using Tapatalk
I'm missing texts about 50% of the time. people are really angry at me for not getting them and then I restart my phone and get 10 texts from the past 5 hours. I can still get calls at that time. Any fix for this?
I suggest trying gingeritis ROM - just seems like a lot fewer bugs bc the base its built off is cleaner.
Im new to Rooting and lastnight I rooted and installed Das BAMF Sense 3.0 RC4.9 on my Thunderbolt and everything is working great ..LOVE IT..But I dont have any Network it will only work on WiFi. Do I need to install a radio to get it working? Please help I cant use my phone right now all I get is No Signal
Thanks, Ken :(
Thanks, Ken :(
Yes, you need to flash a radio. I'm using the Official OTA MR2 Radio with good results on this rom.
See zero neck's guide:
http://forums.androidcentral.com/thunderbolt-rooting-roms-hacks/97307-guide-upgrade-mr2-compatible-rom-radio-mr1-after-root.html
what is the best radio to run verizons network
Your best bet is probably to go with the official MR2 radio. It's the latest one officially released by Verizon, and I've been running it for a couple weeks with great stability.
heres my problem...How do I just load a radio...When I rooted lastnight I thought the radio was part of the rom(like I said Im new to rooting).
Lilrose
