acore problem fixed now I have other issues
Penthor
13
Galaxy s5 active v4.4.2. Deleted contact storage data to fix the "android.process.acore has stopped" problem, now I don't have access to ringtones, alarm sounds, and when I take pics they don't appear in my Gallery. There may also be other problems I have not found yet. I'm new to smart phones but have built and configured several computers. Do I need yo do a factory reset? And if so what will I lose? TIA
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
I would reboot into recovery and clear the system cache. Probably a conflict error giving you grief.
Penthor
13
Golf, thx, I cleared the cache, but still have all the same problems. Will I lose the preinstalled apps with a factory reset?
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
No, only the ones you installed. I always operate under the assumption that a reset can wipe everything, so back up anything important.
Sent from an AOSP M8
Penthor
13
I'm going to try to remap my ringtones and images before resorting to a reset. I found my pics but the ringtones are still missing. If I can find the ringtones and remap everything I won't need to reset.
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
Golf, I couldn't remap so I reset and all is back to normal. Thx
Glad it got fixed. Thanks for posting the follow up, it might help others in the future. See you around the forums.
TexasIndia
