Battery life since Feb 5 update
Change your wallpaper to something dark or solid black. It'll switch you to a dark theme
I know that. I meant like the settings windows, google feed, google assistant etc. I wish google had that option for a true dark mode.
It's been over 24 hours since my phone was last plugged in, and it's down to 59% with moderate use. (And a bit cool to the touch.)
Clicking on your Avatar says you have a Galaxy Note 3. Is that the device you are referencing?
definitely noticed a drop in battery life..... have not noticed a warming issue though.
I'm a very light user (text, email, some web surfing).... before the update, I would have approx 75% life remaining when I would leave work (using WiFi from work).. past few days the battery life is about 55-60%
also noticed that it would loose about 5% just sitting in the stand-by (about 1 hour of inactive use)... would maybe drop 1% in stand-by previously...
checked me settings, no changes made...
no new apps etc..???
have to wait and see..
I clicked on your Avatar to see which device you have. What is a Priv US?
I'm on 40%, last full charge was 4 hours 46 mins ago, screen on time 20 minutes!
It's been on airplane mode for almost half that time as I was working!
This needs fixing asap!
Edit: another 6% gone in the 20 mins since I posted that!?!
That's pretty disastrous.
Obvious questions:
Have you restarted your device to see if that helps?
Have you taken a look at your battery settings page to see what app and system utilization looks like?
If you're intensely curious, you can grab a bugreport and send it to Battery Historian. This is not a trivial effort but shows pretty deep stats that can be potentially helpful when troubleshootinig battery drain issues:
https://developer.android.com/studio/profile/battery-historian.html
I used this tool awhile back and found Accuweather was abusing my Bluetooth scanning location service and causing drain.
I wouldn't take too much stock into people's profiles.. a ton never remember it after setting it lol :P.
When somebody posts, the first thing I do is click on their Avatar icon so I can learn a little about them. I certainly can't be the only one that does that. And Morty, you are using an Honor 8. Have you ever clicked on my Avatar?
I can say I never do since it's 9 times out of 10 out of date
Who are you and what phone do you have?😁
On topic...
My device,regular Pixel 2, isn't having any issues since the update... Couple of screenshots from today and Saturday (I think)..
Obvious questions:
I was at work and didn't have time to investigate but switched it off and recharged, seems to have gone back to normal now 🤨
It's all there if you click on my avatar.
Who is this avatar and what has it done with the real TraderGary? (I don't see any of the stuff you seem to think I do when I click on your avatar...)
When I click on your avatar I get...
And when I click on my avatar I get...
handsome
