Best Xposed modules?
I flashed it about a week ago, worked for a couple days then just stopped. Should i try re flashing? Or will that cause issues without wiping anything?
Posted via my AT&T LG G3 Running Illusion ROM
Re-flashing that install should not cause any issues. Perhaps there are compatibility issues with that particular ROM? Not sure.
Possibly. I'll re flash in a bit and then I'll come back and see if we can fix this problem. It's just weird how xposed worked a couple days then stopped ask the sudden. It may be a compatibility issue. Not suree
Yeah, it's still an Alpha for 5.0 so I would expect a lot of random bugs.
You should try what AndroidHabit mentioned above. It could help your wakelock troubles.
By the way, I am also having issues getting the Xposed alpha to work under my Lollipop ROM, DirtyUnicorns 9.1. But my wake locks are not out of control using just Greenify, so it is possible to tame!
I am researching some alternative methods to tame wake locks.
Okay so i guess is just a bug. And i greatly appreciate your help btw. The only big thing killing my wakelocks is Kik messenger (i can hibernate it but it gets annoying having to open the app every time i want to see if i have any new messages from friends and what not) and Google, but idk if hibernating Google is a good idea..
Check out this post:
http://forum.xda-developers.com/showpost.php?p=59164026&postcount=3082
It got my Xposed working and also let me know that Greenify is not yet working.
Get into the habit of checking things manually, you will love the battery time afterwards.
It's ok to hibernate google.
Lassi876
