ARCHIVED: [Custom Recovery] Optimus S/ Thunderc-sprint
Status
Not open for further replies.
I followed the steps above both via adb push and downloading files to sd card. When I go into recovery mode I am not given the option to install from sd card, only the following choices:
reboot system now
apply sdcard: update.zip (which does not exist on my sdcard)
wipe data/ factory reset
wipe cache partition
Recovery mode does not give me the option to flash from sdcard like the example shown in post above. Can you tell me what I am doing wrong?
Hello,
could you help me. Im haveing the same problem. I dont know where to get this flash image from i have been trying to do this for ever. I just got to root it with ginger break and now i want to flash roms. If you could help me i would be so happy. and tips tricks or just tell me like im a baby would be great.
Hello,
Or you could always try Xionia... Its my personal choice....
I would do any I just Sony get it. I put the img zip on my sd root open terminal emulator and try to follow the script it always says missing flash image and stuff. Its making me crazy and one please help.
Sent from my PC36100 using Tapatalk
You have to unzip the zip file and copy its contents to your sd card. In fact you need both zip files linked at the bottom of the OP. You have to extract both of them to your sdcard, then follow the prompts. It is not finding the flash image because it is a file still contained within a zip. You cannot flash the zip file with adb.
alright kinda noob problem but still a problem.
okay i put both files on the sdcard root. unziped and all like the instructions say. but when i
do the cat /sdcard/flash_image >system/bin/flash_image line i get an error that theres no such
file or directory. and im like its there.
help a noob out please! thanx!
i am new to this hole rom,hack kernal thing someone told me that there is kernal for my lg optimus s that will flsh the new ndriod 3.1 os is that true?where do i get it?
please help. did everything just like the post on the 1st page. when i put in reboot recovery in the adb it reboots to a black screen. please help
You probably have the new video display and drivers. You need to go with the latest xionia recovery.
Issues getting recovery on my optimus s....
I am also getting stuck on the exact same command... Any help would be appreciated.
Status
gaganprasad
