ARCHIVED: [Custom Recovery] Optimus S/ Thunderc-sprint
Status
Not open for further replies.
ok, thanks, just wondering, so I'm ready to flash, thanks for the fast response
I have a question, I have the Optimus S with ZVD, every time I flash a recovery after a reboot it reverts back to the original one, any way of setting it permanent?
The same happened when I tried to edit /init.rc it reverts to the original one, to install busybox I had to copy it to /system/bin then install it /system/bin/busybox --install (it installed in /data/busybox folder, then mkdir /system/xbin (only folder in PATH that won't get erased) then cp -d /data/busybox/* /system/xbin then I erased /system/bin/ls, /system/bin/cat and /system/bin/df
# mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
that line's important
Ok I ran through the instructions exactly, no error messages, but when I reboot recovery it just hangs on the LG screen. I'm feeling dense I admit.
EDIT: Got it, I was in fact being dense. Thanks for the help!
how did you fix this problem?
I've followed the steps for this but when I do reboot recovery.. it reboots..shows me the LG logo and then the screen is blank. It is still backlit like it is showing me a blank screen. But I don't get ANY type of recovery options. Just a blank screen. Tried twice and still no go. I am rooted (superuser asked for access when I typed SU so I know its working)
You cannot use this recovery because you have a newer optimus s, you need to use the cwmr it has drivers for the newer displays.
is it 100% safe to put this custom recovery on my optimus s
Model Number:
LS670
Version:
2.2.2
Baseband:
LS670MVD
Kernal:
2.6.32.9
we can be, but your one of those, "gotta get the last word in" types, so i'll let you win and bow out in humble defeat, oh how could i ever think of posting against you, lol. Happy days will come at last.
dumass myou know why you just said that
Model Number:
LS670
Version:
2.2.2
Baseband:
LS670MVD
Kernal:
2.6.32.9
yes but not this one, you need to put this recovery on instead, you most likely have a newer Optimus S which means the display drivers in this recovery will not work for you, the above recovery will have the display drivers for both the newer and older OS.
So I downloaded the files to my computer, unzipped them, then moved them to my SD card. When attempting to run the second line, cat /sdcard/flash_image > /system/bin/flash_image, receiving error: /sdcard/flash_image: No such file or directory. How do I get past this?
The flash file is on my SD card (not the rar file...the actual file). I copied and pasted the text directly from the post so that I didn't miss any spaces. Any help would be appreciated.
Status
pratikkumarBB
