Cyanogen 6.0.0
Hey anyone experiencing the inability to dl from the market while using cell towers but no problem dl while using wifi.
Sent from my PC36100 using Tapatalk
No problems for me. Been running CM6 from day one. :cool:
Radio signal.
Hey guys I am currently running the latest radio drivers but I am experiencing what seems to be less radio strength when I was running the latest version of fresh. Now is this possible that I'm experiacing less signal strength with the 6.0 mod. I keep going from 3g to 1x. I never had this issue when running HTC Roms. Thanks in advance
Radio signal.
believe or not, i met similar problem, and wifi signal seems unstable either. I gave up at the last, back to Fresh Froyo. all good after substitution.
Radio signal.
I don't believe HTC roms have the 1x icon, so it will constantly say 3g even if you're not getting a 3g signal
Gotcha
I was getting about 500kbs and I went back to HTC Rom and now getting almost 1100 in the same location. The only thing I notice different is pellet on HTC is 6889 while android stock is 6888. How do I update prl in cyanogen Rom
Hey I updated my prl and pri and now I'm getting around 1200 on 3g which before I was getting barely 500.
Does the new rc2 has the normal kernel or the new kernel?
i have problem updating my pri i gave up.........
is it mush of a difference
That is correct, Marko. As I understand it, they are trying to write the code from scratch instead of building on HTC's code. I won't pretend to know exactly how herculean an undertaking this is, but I'm lead to believe by comments that it's not an easy way to go.
I haven't heard any updates from CM other than they hope to add that and HDMI to 6.0.2 (maybe).
Thanks bluger. I have yet to root but want to make sure there's a ROM out there that has 4G activated. Is the AC ROM the only one with 4G right now?
Hi, I had to install a HTC sense rom and then update my pri. Once doing so you can restore a backup file of the cyanagon 6.0
Noooooo...
Any Sense Rom will have 4G Working... :confused:
I am not rooted, I'm not a hacker, I'm not a student with hours of time to read up on message boards and I work a ton of hours and have a family life. I am sorry for offending you with my lack of knowledge on hacking smart phones.
Nobody was insulting you here man. Calm down.
For all those having trouble updateing pri, nand back up, flash AC rom, wipe everything with RA. clockwork haas lower success rate, then do the ##786# stuff . Rinse and repeat.
Geez... By now you would think people Would understand my Humor...
abbbce42-bf43-4d96-8232-5f1a060c145c
Hey,
is anyone here experiencing issues with the camcorder? Replaying videos i get choppy playback. Anyone else experiencing these issues?
tota
