Cyanogen 7
I skipped from ED01 to EC09 and thus far it is performing well. I recorded about a 15-20% increase in my 3G speeds (via running several Speed Test runs from same location) so that was impressive. GPS takes quite a while to lock, however (for me). Is ED04 good for GPS?
my gps worked great on EC09.... ED04 was fine as well
Going into settings - profiles - default profile and then down to application groups allowed me to turn off led notifications for email etc.
Anyone know if there's a calculator apk from the commrom's that I can flash onto CM7? I like that calculator better than the one included in this build. Also, does anyone know if bluetooth dialing is possible on the current build?
Reactions: jmc81
Is this logic right? And I hope not - otherwise. I'm immediately gone. I'm hearing that charging won't work when powered off. If this is the case, then what happens if the batter of the phone ever dies? S.O.L? Doesn't seem like putting something like that out should even be legal?
And did anyone else experience the screen staying black even when pulling it away from your head?
And I was playing in the settings last night, and I found something about speakers (almost like a calibration) that had options ... Weakest, Weaker, Weak, Normal, Strong, Stronger, Strongest. I don't know where those are - just wondering how to get back to it? Thanks.
1. There is currently a bug that boots the phone up when you try to charge it with it off. Not really anything you can do about it.
2. This is another known bug. You can push the volume up/down to turn the screen back on during a call. Not a big deal if only a minor inconvenience.
3. That was the DSP Manager app that comes with CM7. I have not messed with it so I'm not sure how it works exactly.
Been on CM7 for a couple days now with the Glitch Kernal (low leak) . Had to flash GAPPS through the Rom manager app. Everything is fast snappy I am overall very happy with it, if you hesitant don't be it works great just make sureyou Odin the blue cwm recovery.
Just a fast question does any one know why the home menu back and search keys wont lite up until after you touch them. Is there a setting Im missing I did some searches and all I can find is info on blm?
Thanks
Sent from my SCH-I500 using Tapatalk
I believe so. I installed the Voodoo Control app and it has sound settings.
You're right it will work. I thought I read somewhere not to use anything voodoo . Or . lagfix
Thanks for the response
Sent from my finger to my phone to this post using Tapatalk
My keys don't work at all sometimes. I have to lock/unlock the phone and then they work. Anyone else experience this too?
Mine light up normally as far as I've noticed. I don't think I have a volume in calls problem, either. At least not that I know of...
The only thing that bothers me now is the video quality with the camera app. It's jumpy and jittery. For that I'll have to wait.
Yeah the video jitters is odd an doesn't happen all the time. A temp fix is I found that lowering the quality one step down seems to avoid the Max Headroom stuff. Also, I think it did not happen when using the MIUI camera, but I'll have to test that theory out.
* yeah I guess I was right - I am using the MIUI camera - it's pretty nice (although I guess I did like the Touchwiz camera). Only thing I heard is the color effects will not work, but I don't need those - http://forum.xda-developers.com/showpost.php?p=15880235&postcount=2972
Does anyone know how to change things in the status bar... i want it to show my battery percentage, but i dont see how to do it in cm7..
Menu>Settings>CyanogenMod Settings>Interface>Status bar tweaks
Settings - Cyanogen Mod Settings - Inerface - Statusbar Tweaks
*arg beaten by a moment
if you want to add/delete/change the items in the drop down menu go to:
Settings - CM Settings - Interface - Notification Power Widget - Widget Buttons
Start playing around and I am sure you will be VERY pleased.
Now that I see it. I can't believe I had missed it.
I love the RealCalc app from the market. It can operate in "normal" mode or in RPN for those engineer types (like me) that learned on HP calculators...
I have used the calculator app on the UKB 2.0, not sure if it would work with CM7, though I don't know why it wouldn't.
No members online now.
kctraci1
